Frigidaire top loading washer leak
washer leaks from underneath. water appears to run from the top of the tub down the back (outside) I have found the screen at the bottom of the basket needing cleaned hhowever I have remove the six bolts form the basket but cannot remove it.Is there something else I need to remove?
Please post a model number so we can see exactly what you have.
If your machine is less than one year old it should be covered under factory warranty, so check with the warranty service.
