My Front Loader Washer Tub appears not be supported by the right side tub spring. It is hanging cockeyed in the washer to one side.
I removed the top panel to take a look I saw the right side spring had pulled thru the plastic mount on the tub. I can remount the tub to the spring but I am sure that in the next wash cycle the spring will pull thru again. Is there a good fix to this? Must I purchase a new plastic tub insert? It looks like this is a major repair job with all of the cement balance weights. For the cost of the tub and my time I may just trash the washer and buy a new one. I hate trashing a good unit because of some POS plastic piece.
Frank,
Thanks for the info, that should be the answer I needed. The other thing is the tray did not do its job because it ripped away from the wall pipe one time when the washer was out of balance. I’m trying to figure out how I’m going to get the unit into the new tray up over the lip once I install a new one.
