frigidaire washer ERROR CODE E43
I have a frigidaire washer. Last week it was beeping and flashing on and off without allowing me to stArt any cycles or turn it off or on… it did whatever it wanted.
i could not even run the diagnostics. I unplugged it for the weekend and today plugged it in and got it into diagnostics.
as you turn the dial to go through testing each component all worked until the test for drain and spin. It drained did not spin and E43came up on the display (control board problem)
There are 2 control boards so not sure what next… please help! I need to get it up and running as affordably as possible and both boards are at least $248.00 ea
Angie
