Frigidaire Washer - noise and plastic shavings
Recently washer started making a grinding/rubbing noise. Becomes quite loud during fast spin.
Examined today and found plastic shavings around the front of the drum. It appears that the drum is rubbing on a plastic ring that is beneath the rubber door gasket.
Seems like there is some up/down play on the front of the drum, but I can’t make it so it doesn’t rub. Also seems like there may be some front-to-back play, too.
Bearing??? How difficult to replace, if so??
Anybody???
Are there any posted instructions for how to replace the back-half of the outer drum??
Surely somebody here knows…
Are you trying to get it back on the tub, or the front panel?
When microwave is cold, it starts up slow than gose to the right speed
when it gets warmer. What is the problem?
