HELP!!!
I have been experiencing a problem with my washer and I think it has to do with the control panels circuit board. I first noticed the problem about 6 months ago when the washer would come on briefly and the lights on the display would blink and go off when the washer was just idol. on several occasions the washer would not turn on at all. One day I unpluged the washer to check the electrical connections and found nothing wrong. I put everything back together and pluged it back in and like a miracle it worked. I assumed it was a loose connection someplace or something, but the washer resumed normal operation, untill a few days ago. The lights on the display come on briefly and then go out and this happens randomly. The display does not show any error codes. I am assuming that the circuit board is bad.
Has anyone experienced the same problem?
