frogisimo
dryer leaves burn marks on clothing. I have replaced the thermostat in back of the drum. It didn’t burn the clothes for a while now it’s doing the same thing as before. any suggestions?:confused:
Mark,
Most likely the problem with your dryer caused by a bad gas valve coil (13 & #14 on the [AP3094251](http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=124022&&model_id=265842"]burner break down diagram[/URL]).
Here are the break down diagrams for the Whirlpool dryer http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=124021&&model_id=265842
