Front knob
How do you remove the front knob to replace the main control board?
You should be able to just pull the knob forward if not it’s attached and you have to removed the whole touchpad here’s the schematic to help you
http://www.appliancepartspros.com/control-panel-parts-for-frigidaire-atf8000fs1.html
ok thank you.
