remove stackable Frigidare washer power knob
How do I remove the washer power knob to replace the timer?
Look on the back of the timer. There should be a rod with a cutout part in it. Use a screwdriver in the cutout to pull back the rod and the knob should release.
Let us know if that works, or if you need more info.
