What are the procedures for replacing the main bearing on rear tub assembly. Looks like the tub needs to be seperated at the center before bearing can be replaced. Am I correct ? Thanks.
Unfortunately the rear bearing is not replaced as a separate part. You have to replace the entire rear tub section.
I don’t know why Frigidaire made it like this, they just did, and most folks have decided the repair is not worth the cost. I tend to agree, but if you like the machine, are experienced at repairs, want to fix it, and do not want to replace the washer you should do so.
