funky monkey smell
My friend was cleaning the bottom of my fridge. I underand that the compressor is underneath. Now my family is smelling something that I imagine freon would smell like. A chemical smell when we open the doors. Could it b harmful? It seems to be cooling fine, for now… Help!
— Begin quote from msnancy;340989
Someone please reply to my funky monkey smell post! I need some advice, bad!
Ms Nancy,
It’s not a freon, chemical leak, your fridge would have quit cooling, if it was.
Is the odor in the freezer compartment as well ?
Did you use a chemical cleaner to clean the inside liners ?
When you get the time, you might want to try,
Washing everything, including the shelves and bins on the door, with HOT soapy water, and rinse several times.
Take a coffee cup saucer and set it on at least one of the middle shelve, and put a couple of ounces of coffee, vanilla extract, or a small box of baking soda(you could also use a frabric softner sheet).
Give it a couple of days and the odor should be acceptable.
:cool: :cool: :cool:
