I need to replace the main jet holder for front right and front left burners. On the diagram the parts are numbered. The front right has numbers 8 and 10 for the part. The front left also has the part numbered 8 and 10. Which part number is correct? LP gas is being burned. Not natural gas. Notice the back left and right main jet holders are numbered 9 and 10.
Ice Maker is dripping water at the front.
What is the correct part that I need to purchase to correct the porblem.
- Ice Maker
- Valve
- Do you have a kit
— Begin quote from mark mitchell;266220
- Ice Maker
- Valve
- Do you have a kit
Mark,
We need a good model number to research and help you,(the one you supplied is not correct).
You could need all the parts you listed, but we can’t be sure without a model number.
First thing to look for is:
Is the Refrigerator level in both directions ?
Is the icemaker level inside the cabinet ?
After those checks, if problem not solved, repalce the fill valve.
Good Luck,
