My maytag LSG7804AAE gas dryer does not heat up all the time. It only works after a break of a few hours between loads.
The glow ignitor works fine but the gas dosen’t come in, instead you hear a clicking noise and after a few seconds the ignitor turns off.
Any idea?
Most likely the problem is a bad gas valve coils (#7 & #8 on the [B]diagram[/B]).
- The coil kit AP3094251
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=866101&&model_id=26383
Would it be the Hi-Limit Thermostat?
— Begin quote from sruliz;229272
No, I do not think so. If the high limit thermostat is bad, the igniter would not glow.
