Gas dryer heat cycling not correct
The dryer was taking forever to dry. After taking the lower panel off we cleaned the dryer and vent system of lint. Ran the dryer and watched as the ignitor started the gas and watched it go out after about 10 seconds. We replaced the coils and still have the same problem with the gas only burning for about 10 seconds before going out. The dryer then conitnues this over and over. We need suggestions on the next step to make this work again.
After reading other posts, I’ve found the problem. My vent to the outside world goes up through the roof and after sending down a shopvac hose we found the clog. Everything is back up and running.
Thanks.:slight_smile:
