I just bought a Maytag Ensignia gas dryer, Got it home hooked it up an it wont heat up, It spins fine. This is my first dryer I have ever owned so I have no idea what to due. Can you please help me by telling me what parts might be needed & What the part number is to all parts? Model # MDG8757AWW Serial NO. 13746714AX THANKS so much, Jacki
The first thing you need to do is make sure the ignitor is glowing brightly and if you have an ohm meter check it for continuity.
Nat
