Maytag Gas dryer won't heat up!
:confused: Hi I just bought a Maytag Ensignia gas dryer, Got it home hooked it up an it wont heat up! It spins fine, an I reset the power breaker. This is my first dryer I have ever owned so I have no idea what to due. Can you please help me by telling me what parts might be needed & What the part number is to all parts? Model # MDG8757AWW Serial NO. 13746714AX THANKS, Jacki P.S. GENE I need your help with the part numbers & names :slight_smile:
Did you hook up the dryer yourself? If yes, how did you do the gas line? Is it open?
Here are the break down diagrams for the Maytag dryer http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=689348&&model_id=49254
No I didn’t hook it up myself, The pluming man did. I did check to see if the gas was on & it is. The turning handle, is turnt the same way as the gas line exackly & I was told thats how I can tell if it was on. The dryer is a used one, I was told it worked. It will only tumble but no heat. Can I replace the parts myself if needed? I am willing to replace the parts, Is it easy to do or am I better off paying an appliance guy to come out? I was told it could be the coils, Gas valve, Thermostat, fuse or the Ignitor. I know a gas valve cost alot. I don’t have a ohm, volt meter to check for continuity, should I go an get one? Is it hard to test the parts myself? Which parts can I check with a ohm meter? Thanks Jacki
The water dispenser drips
