My son broke the exterior glass of the oven door. We placed an order with GE and received a replacement glass. However, there are no instructions about how to install the glass for the oven door. Help?
the model # is JGBP85CEA1CC
Thanks and hope you can lead me to a way to install the glass on the door.
[INDENT]I have a kenmore 80 that thumps every so often on spin allmost sounds like gears stripping or springs poping. I allready had the gear box apart and found some worn teeth but none missing or broken it didnt seem like it was the problem. The spanner nut was tight on the shaft. any ideas my wife is going 2 kill me if i dont get this thing fixed
[/INDENT]
