Oven Repair
The Door Glass Was Broken, Part # Wb36x10143. I Understand Ge Has Discontinued The Oven Model.
I Need Help In Locating Sources For The Replacement Glass Door.
Thank You.
I’m not sure when it has been discontinued. In such situation only hope for you is to find a small local parts store where it might be in some dark and dusty corner. You also can try to search the net for old used range like yours for sale.
Looks like this is just a glass and does not have holes etc. for the handle so you could measure where the glass fits to get the size.
Then take your tape measure and go to a few stores (Sears would be a good bet as the Kemore is from many different manufacturers), to see if you can find a front door glass on a modern unit that is the same size as yours.
Then get that model number and see what a replacement is going to cost.
Just be sure it is not bigger, slightly smaller should be OK.
