When finished using oven and the timer, a short while later the"beeping starts" and I get fault F 10. What is causing this? What part is needed? I tried turning off the breaker for awhile and even pushed "reset" but problem still exists.
— Begin quote from ddlong;274221
DD,
The F10 code on your unit indicates a bad oven temperature sensor.
[part]AP3969435[/part]
Did this start occurring after a self clean cycle ?
Did you notice if you had any overheating, cooking problems ?
have you got tools and a meter to access and check the resistance of the temp. probe ?
DD,
Based on the manufacturers information,
You most likely have a bad oven temperature sensor
