gas range oven heats up but then shuts off
Whirlpool SF367LEMW gas range oven heats up for maybe 10 or so minutes but then shut off. Lights on touch control stay on but heat just quits and does not turn back on. A & E service replaced the touch control module, spark module, oven gas valve, and oven spark ignitor but problem persists. This gas range is not old, what can I do?
Have they replaced the Bake burner?
The bake burner was replaced when they replaced the spark ignitor. All other parts were replaced withing the last 6 weeks.
Remove the burner and drill one size bigger the lighting holes circled red on the upper attached picture.
