GE Adora Front load washer : worn drive pulley
I have a front load GE adora washer model WHDVH626FWW. For a while now I noticed it smelled a little funny and underneath it looked like there was some black dust which I now know is from the drive belt. It stopped spinning today and I opened up the back and the belt was off the pulley. I also noticed the pulley had some play in it even though the bolt was tight. If I replace the drive pulley and nut will that fix the problem? Is it likely the pulley is worn and that is what is causing the play or would it be the drive shaft? Appreciate any help.
