GE Control Assembly, differnet than original.
G’day,
I’ll try and explain best I can. Bought a new control assembly that is not quite a perfect match. I have 2 plugs that don’t match up with new assembly. One has 2 yellow leads that go to a spray botton. (not really concerned about that one) The other has a black and a white lead running from it and the plug has openings for 3 prongs. It plugs into CN3.
There is not similar place to plug this one in??
Any ideas what this is for and how important it is? Maybe some kind of work around?
Thanks!!!
The number is WH12X10178
There’s your problem, if you posted the correct model# you need the WH12x10138 board. You got the wrong board.
I bought a new auger to replace the broken one in my GE freezer. I have dis-assembled everything except not being able to remove the blades from the old auger. I have read all the posts about replacing auger and cannot seem to find the right thing to do. it seems from your previous responses, the bales are supposed to slide out through the spacers but everything are so tightly fit and even with some force applied, they’re not coming off the old auger. i have applied some lubrication but that did not help, i do not want to use extra force as i may break something. please help me with the right tip to get such tight fitted in blades off the auger, thank you.
