Hola all,
I’m a tech and have run into a problem. I was working on this unit today and found a 3x5" PC board directly behind the Timer Assm. that was shorted out. no problem,right? well, I can’t find it on any of the tech sheets and our usually helpful supplier is also stumped. the part is a white PC board with a relay and some transistors on it. it measures aprox. 3x5 and has one four contact terminal on it. I’d apreciate any input.
thanks muchly,
Bryan
