Im looking for a control board for a GE Washer Mod. WBSE2090A2WW. The one in parts diagram is longer than mine. Mine does not have the extension to the right (when looking at circuit or back side) that looks like it has 2 additional knobs. Mine only has 2 knobs, NOT 4. Circuit board looks the same. Can anyone explain.
The original board is no longer available. This is the replacement. Remove the stems from the other controls. Make sure you transfer the model select plug from the old board to the new one. It is the plug with one or two jumper wires on it.
Eric
Thank you Eric. So if I understand I just wont use those additional controls and just insulate that additional circuit board from making any connection to metal and all should work OK?
Yes, that is correct.
Eric
