The front right burner goes immediately to high no matter what you turn the knob to. You can’t regulate the temp and turn it down. Could it be a problem with the element or with the control?
Replace the control. The only thing the element knows is to come on. The switch tells it what to do. Tom http://www.applianceeducator.com
