GE Radiant Cooktop - Burner regulation NG
The largest burner (and the one I use most) on the cooktop defies regulation; it loves to be on High, and when I try to turn it down to medium, it just stays on High. If I turn it to really Low it will respond, but in the mid range I have little to no control. All the other burners are fine. Any ideas on the cause, and is it cost effective to get it repaired or should I just replace it?
Thanks:rolleyes:
Where did you order the part from?
