GE Double not getting hot
I have a GE Double Oven JKP27W. The bottom work fine. The top bake element will not get hot or will the top broil element get hot. I can turn broil or bake on and touch either one and they will not even get warm. Clock works, lights work.
Thank you
Your model number seems to be short several digits.
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=JKP27W
I did look at one of the units and it does show a limit switch in Section 1.
Perhaps this is open.
I am guessing here as I do not have a wiring diagram for this unit.
GE likes to keep all tech info a secret.
