My GE electric dryer timer won’t advance in the automatic modes.(DRXR473EWOWW). I replaced the timer in a recent purchase from APP.com:(. The dryer dries in all modes, but the timer only advance in the timed drying mode which is OK, so it is usable. I see in the parts list a resistor and thermostats, but have no idea where to go from here. I’ve cleaned all the duct work front and back.
If you have a fax no. I can fax wiring diagram to you if that will help. the wiring diagram does show a inner and outer heating coil. My question is do I remove a side panel to get to the heating element?
If it happens to be a heating element, I’m not going to put another $200 into and old washer. I already made a mistake thinking it was the timer $80 dollar latter I’m no further ahead and a Repairman will probable be in the $400 range… I just keep using it till the other heating element quits. thanks for trying
