GE Dryer will not start
Bought Dryer used. It works like a dream at the place I purchased it from. When I get it home, I turn the timer on and press start, it will not do anything. It is straight wired from breaker box. It is the only thing wired to that particular breaker box. According to the electrician, everything is good with the wiring of the breaker box and we are getting 22o to the back of the dryer. However, when we set the timer, the voltage behind the instrument panel(at the timer) drops from 120 to 76. Also, when the timer is set, you can hear it ticking as though its working, but when you press the start button, it stops for however long you hold it. I have 220 coming out of the breaker box and to the back of the dryer. Please help. Thanks!
