GE Electric Convection Double Wall oven won't heat up
GE Electric Convection Built in Double Wall oven.
Top oven works normally both Electric and Convection. Bottom oven is not working. Temp is entered to turn on. Display shows 100 degrees and looks like it will warm up normally but there is no heat. Bottom oven is Electric only and used 10% of the time compared to the top oven. The bake element on the ceiling of the bottom oven looks clean and without damage. Any suggestions what part I need or troubleshooting suggestions? Thank you!
