my ge fridge quit working on both sides. fridge and freezer nothing runs, and the digital temp control does not light up. ice maker and water work, all lights work, just no cooling no temp diplay. the board inside the temp display has been replaced and did not make a difference. wondering if anyone had any other ideas thanks:eek:
Most likely the problem is a bad main control board (#801 on the [B]AP4297272
- The part number for the main control board is [URL="http://www.appliancepartspros.com/partsearch/ctrfs.aspx?part_id=4297272&&model_id=208319&diagram_id=21454232)
Here are the break down diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=21454232&&model_id=208319
