My GE front load washer model WCVH6400J0WW will not spin can someone help me with troubleshooting the problem?
Did it show any error code?
Run the washer in the Service mode (the instructions are attached) and post the results.
— Begin quote from Gene;457026
Yes E22 and I’ve been through the service codes and all seem to work ok except for the t07 didn’t ever pump out the water, it filled and then just kinda set there showing 120. And my machine I guess doesn’t have the t08 or the t09 modes.
So what did it do when it came to t08 and t09?
— Begin quote from Gene;457183
beeped twice on each mode but thats all. the instructions i had said that some models may not have this mode. I’ve checked the pump drain, the inlet water supplies and hoses all seems ok.
Check the water valve solenoids for continuity. Each solenoid coil has an approximate resistance value of 1.1 Kohms. If the reading is incorrect, replace the water valve.
Check for 120 VAC to the water valve solenoids while the control calls for water. Try it on all different water temperature settings. Post the results.
— Begin quote from Gene;457200
ok, where are the water valve solenoids located?
