GE Front Load Washer Not Spinning
Hello All,
I purchased my washer from Home Depot Feb 2008, and it stopped with about 22 min left for the wash. My wife was washing 2 comforters, so they were probably too heavy. The pump works, but the drum doesn’t spin. Also, when starting a new wash to test it, the tub didn’t fill.
I cleaned the pump filter. No change. I started the test. t01 was set to "5". I’ve seen nothing that indicates what code for my model. t02, only error code was E54 "Lost communication between control and motor drive". Suggesting to test t10 (tumble) t11 (spin) t14 (spin). On both t10 and t11, when I push the pause/start button, it just beeps 2x’s and displays or does nothing. I have no t14.
Test t03 for software, I get codes for "cod" I get codes for "ee", but on "INV" just "—" no numbers. t12 test for pump, no problems. Fills fine.
Looking at the bottom of the drum I see a red & yellow wire just hanging.
Resetting and restarting no error codes, but still does not fill or spin, just drains.
Any ideas?
Thanks,
Jonathan
Jonathan,
Your situation sounds exactly like mine at this time. My GE WBVH6240F0WW washer does not spin or agitate. I’ve check the belt and it seems fine…what’s next? Thanks.
Calcam
