Ge front load won't was
I ran every diagnostic and everything works in diagnostic mode.replaced the inlet valve which fixed a leak but still won’t wash. What it does if I try to start a load, is the drum goes left 360 the right 360 then stops runs the pump then unlocks the door. Thinking it’s the control panel but not sure.Any help would be greatly appreciated :slight_smile:
