GE gas oven
[SIZE=4]My oven does not turn off. I had to unplug it to get it to turn off when I plug it in same thing its still on. Now I’m not sure if it is the ignitor or the valve assembly, or am I completely wrong and its some thing else some one please help.[/SIZE]
[SIZE=5]Thanks in advance[/SIZE]
Hi.
Check if the oven thermostat knob is not stripped or broken inside. if the knob is OK than most likely there is a bad oven thermostat.
You can check it for continuity in off position. If there is continuity - replace the thermostat.Do not forget to unplug the range.
The thermostat WB20K8
The knob WB03K10142
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5243520
Thank you. Post the results.
Simon.
Thanks for the advice I’ll check as the thermostat as soon as I get home .
You are welcome.
Simon.
