All burners work, broiler glows and starts up but when set oven temp the electrical ignition wont come on? Any Help
yes it is most likely the ignitor. a good way to be sure is to check the gas valve for continuity. but in thirty years, i have only replaced and hand full of gas valves, and a ton of ignitors. tom %url%
Larger upper oven bake element won’t heat above 325, even after being turned on for 45 minutes or longer and temp setting at 400. Element does heat, but not above 325. Do I need a new bake element, or is it something else that is wrong? Everything else on oven (broiler, and complete bottom oven work fine). model number rde2400 p2; serial number m 10222352.
