my oven does not fire up but broil and the 4 top burner no problem. igniter works but no gas coming out. what part do i need to replace to make oven work again
you think its the valve thats the defective part
Hello,
You may want to start the troubleshooting from measuring the current drawn by the Bake igniter. If the igniter is flat and the reading is 3.2 amps or less then the igniter has to be replaced.
The model number you posted does not come up. Verify and repost it please.
