The Hot Cooktop light stays on all the time, even when all burners are off and cold. I do not have ready access to a volt meter. Can somebody tell me what the common cause (specifically what part) of this failure is (I suspect each burner has a sensor), and if there is a way to detach wires individually to isolate the burner?
Related topics
Hot Cooktop light will not turn off | 1 | 2915 | May 8, 2010 | |
GE Range hot cooktop light stays on | 3 | 4776 | July 2, 2014 | |
Hot Surface light stays on when no burners are on | 1 | 39000 | April 9, 2009 | |
GE glass to electric cooking range .Hot cook top light stays on always. | 3 | 3441 | November 1, 2014 | |
hot surface ligt | 2 | 537 | August 30, 2017 |
