My GE washer has begun making an extremely loud noise during the spin cycle. It’s a pretty consistent noise, and really loud. Any help would be appreciated.
Thank you.
Thank you.
— Begin quote from BMike74;160857
Thank you.
As an update, my wife just emptied the washer after it was done. I was trying to rotate the drum pushing around the agitator, and it sounds like there is water still somewhere in the washer, perhaps between the inner and outer drum.
I have a small leak coming from under the washer for a period of 5-6 washer load runs. I opened the back panel, wiped up the water, ran the unit through a normal cycle and can’t see a leak, no addition water appeared. Any idea what could be happening?
Since it stopped it is possibly condensation, but more likely the seal is beginning to fail.
Here is the part,
but you need to search the internet and find a Neptune Service Manual to download (your model is discussed at the back) for how to do it.
