Each time I open the door to my GE microwave it trips the breaker in the electrial box. I reset it and the lights on the microwave come back on. As soon as I open the door again, the same thing happens. The fuse in the microwave is good. I think it might be the door interlock switch. I’m seen this problem on several questions on the forum. I understand there are several switches on the door. Should I replace all of them. Any suggestions how to solve this problem. Could it be anything else other than the door switches or interlock that would cause this problem?
Related topics
GE Monogram--opening door trips circuit breaker | 0 | 2711 | August 8, 2011 | |
GE Microwave trips fuse when the door is closed | 1 | 1008 | December 17, 2014 | |
Microwave Door Causing Circuit Breaker to Trip | 1 | 3055 | October 12, 2012 | |
GE Tripping Breaker After it run | 1 | 1279 | March 10, 2015 | |
Microwave runs, but won't heat | 1 | 1425 | October 16, 2013 |
