GE Microwave trips fuse when the door is closed
Hi,
I was fiddling with the control panel today because I have several keys on the keypad which aren’t working.
Anyway, once I closed everything back up and power back on, everything is fine until I close the door. Then it trips the breaker.
I checked all 3 interlock switches with an Ohm meter and they are performing as indicated on the wiring diagram that came with the microwave.
Any other thoughts on what could be causing the trip? The door seems to fit snug and I hear all 3 interlock switches engage when I close the door and release when I open it.
I would appreciate any thoughts or suggestions.
Michael
