Ge Microwave Door Panel Replacement
[LEFT][COLOR=#000000][SIZE=3]Below is my original question and response. However, I did not get a clarification as to what is a "short out capacitor". Also since I am faxing the instructions to my elderly mother in Puerto Rico, do you have a diagram that I could use to demonstrate the instructions?[/SIZE]
[part # AP3994516](javascript:void();"][SIZE=4]I need to send the door panel to my mother who lives in Puerto Rico. Can you tell me the instructions to give her in order for her to change the cracked GE door panel. If by any chance those instructions are in spanish, I would greatly apprecited. Thank you.[/SIZE][/URL]
Asked by Claudia for Model [URL="http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=part # AP3994516)
Claudia, We don’t have a spanish version of the manual available, but here you go : To Remove Door: 1. Remove power, top grille and short out capacitor. 2. Remove the 4 (2 on top & 2 on bottom) 5/16" head screws on door hinges and #2 phillips head screw on top. 3. Door will pull away from unit with the hinges attached to the door. To Remove Door Handle: With door open: 1. Remove inner door trim. 2. Remove door handle screws. You will need a stiff blade putty knife or screwdriver, to insert between the inner metal door panel, and the outer plastic frame. You will need to pry up and out on the plastic frame tabs, until they are dislodged from the metal frame, you’ll need to do this all the way around the door. 4. When reinstalling door reverse procedure. Good Luck and Thanks
Read more: http://www.appliancepartspros.com/questions-for-GE-PANEL-DOOR-AP3994516-qid22356.aspx#q22356#ixzz1XHOeIqj0
http://www.appliancepartspros.com [/COLOR][/LEFT]
Drier has power, light turn on when door is opened. Checker the breaker box anyway…All good. Timers appear to be working and Start clicks after Timer is cycled. Thermo fuse has continuity. Checked all connection and cleaned machine as I went. Nothing happen…
Thanks in advance,
Wild Bill Tex :confused:
You seem to be missing the first three digits of the model number.
Sears/Kenmore numbers are usually 3 numbers, a period and then an additional 8 numbers.
