Hi everyone! I have an about 18 years old GE monogram fridge which is not getting enough cold in the fridge section ( right one ). I checked the air, coming from the freezer ( on the top left corner in the fridge side). Found that it blows very slow. But when I opened up the left freezer door a little, it started giving me much stronger air pressure. The problem is - I couldn`t found the return - it seems to be just one air way - kinda in to the fridge ( behind the dumper on top of the fridge side. It is obviously not a super common design but like I said - the fridge is about 20 years old. Where should I clean the air duct with steamer? Inside the freezer I think but I do not know exactly.
Related topics
Ge Monogram | 1 | 405 | July 13, 2015 | |
GE Monogram - air leak/icing up/temp variations | 1 | 2421 | September 6, 2012 | |
GE monogram fridge not cooling properly | 8 | 64452 | April 7, 2021 | |
Monogram Fridge is fine, freezer not cold enough | 16 | 25143 | May 31, 2013 | |
Ge monogram 42" side by side not cooling well | 1 | 1 | May 15, 2020 |
