GE Oven and Broiler won't turn on
Hi I am hoping you can help me troubleshoot if it is truly the igniter that needs to be replaced on our oven. I took pictures of the inside part of the oven and have attached them to this email.
Our Oven and Broiler do not work the range stove-top does. My husband said he smelled gas when he had left the oven on to heat for about 10 minutes but it was not hot. My husband actually was able to ignite the front range stove top and the broiler ignited?? He said if you put it on broiler then you will see it will start to glow but nothing will ignite or heat up.
Can you please help me troubleshoot through this?
Thank you!
Model# JGBS17PEA1WH
Serial # is M2125018P
Kathya
Is anyone out there???
