Just moved into new house and encountered a weird oven. All of the buttons make sound when I press them and the heat comes on. When I hit "bake" then + a single digit will appear and go from 0-9 when I hit + or -. There is no clock or actually temperature given. It’s like the right side of the display isn’t working. Any advice or help would be greatly appreciated. Thanks!
Just pulled the oven out and checked wires on the control board. Everything seems to be plugged in. I have a multimeter. Can i narrow down what needs to be replace with that?
Most likely the problem is a bad control board. There are no instrumental tests to verify it but there is nothing else what can cause it. It is recommended to order the faceplate together with the control board because it’s adhered to the board.
