[SIZE=1]This is a GE Profile built in electric oven (approx. year 1998). When oven is set to Bake at 350, it comes up to set temperature, maintains it for about 1/2 hour, then F3 error code. Replaced oven temp sensor unit. Still receiving F3 under same conditions. I think next step is to replace the oven control (ERC). Mfg. part # is WB27K5273, now referenced to new part # WB27T10265. Your item # is AP3141629 (oven control). [/SIZE]
[SIZE=1][/SIZE]
[SIZE=1]QUESTIONS: Is the oven control part the next step to try? The configuration of the part is different than the original, so it will probably require some custom wiring. Does the part come with a wiring diagram/instructions? If so, could I get a copy of this before I purchase the part? Thanks. [/SIZE]
Do not rush with replacement of the control board. The first thing I would do is remove the oven from the cabinet, remove the back cover and check the wire harness from the the oven sensor to the control board. Eliminate the old sensor connection to the wire harness and reconnect it, using a high temperature porcelain wire nuts.
- The part number for the high temperature porcelain wire nuts is AP3440522
— Begin quote from robjcici;21052
I have similar symptoms. However, no error code appears (it use to) and I have a permanent blinking "locked door" message. I would like to try to fix this myself as it is the third time in the last 5 years this has happened. We had a ge appliance repairman replace the controller twice. But it was very expensive. I, too, would like to know if it is apparent how to (re)wire the new controller before I buy it. Any other advice would be greatly appreciated as well.
We have replaced the sensor and are still getting the error messages. F5 then F3.
The model # JRS04B0W2BB.
What do we try next?
I would recommend to replace the control board next. F3 & F5 error codes are absolutely not connected between each other and that makes the control board the first failure suspect.
- The part number for the control board is AP3189149
Here are the break down diagrams for the GE oven http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=579849&&model_id=216067
After measuring the resistance of the oven temp sensor at 1083 ohms, I moved on to checking the ERC (control board).
I found the male pin header connector–that connects to the temp sensor to the ECR–was wiggling and loose. After labeling all the wires to their respective locations, I was able to remove the ECR from the oven, carefully open the electronic assembly, and re-solder the header pins to the PCB.
Seems that the wires from the temp sensor to the header are somewhat short and opening the panel caused the solder joints on the header to break and become intermittent.
Thought I would pass along this fix as previous posts had helped me locate and repair the problem. Thanks to all for your help!
After reading the previous post I also traced my F3 code to a bad solder joint on the temperature sensor male pin header. Thanks for the lead!
My GE oven control/clock panel was beeping and turning the oven off and on. This went on for 6 months. Then one day the bake element burned in half and shot sparks every where. So, I replaced both with GE parts. The bake and broil did not work when put it all back together, about 20 mins later the bake element started working, then the broil as well. I turned the temp up and down, off and on, every thing was working perfectly. I tried it again this morning and again NOTHIng! I set the temp and I hear a click, temp shows 100 and never climbs. Please help me we have been with out a range for 4 weeks now and microwave dinners are getting very old. Thank you so much Mike Saylor.[LEFT][COLOR=#000000]
Read more: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/104260-bake-element-new-but-not-heating-please-help.html#ixzz0sdUwUVfY
[/COLOR][/LEFT]
— Begin quote from Mike Saylor;236460
[LEFT]Read more: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/104260-bake-element-new-but-not-heating-please-help.html#ixzz0sdUwUVfY
http://forum.appliancepartspros.com [/LEFT]
How Do U Wire Old Oven Control Up To New Oven Control Ap3189149
the New Oven Control Has More Pronges On It Then The Old One It Has Where The Bake And Broil Opn Control And New One Has 3 Relays Old One Has 2 Relays
