GE oven / microwave combo
Hi,
My customer owns a GE oven and microwave combo built in. I can’t seem to find the exact model number on this sit.
my unit jkp86soh4ss
similar ? jkp86sh4ss (does not use the "o")
Are they the same?
The oven went bad, turns out it is the DBL relay on the keyboard circuit board, I temporarily jumped it…all is good. If the other similar model number is the same, I would consider ordering the keypad assembly AP3793418, but does it include the actual circuit board with the relays?
The microwave too went bad, seems to be the hv section, I will do more tests to isolate the diode vs. the mag, vs. the hv transformer.
Is the similar model number above the same as my unit?
Greg :confused:
Greg,
In most cases GE does not use "O" in model numbers for diagrams and/or part lists. So the diagrams for the model number [MODEL]JKP86SH4SS[/MODEL]is what you really need.
According to the problem description you posted, the correction is to replace the oven control board.
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5204311
