I have a problem with the oven control. The lock light for the door indicating that it is the self clean mode flashes off and on also the oven door locks randomly. All other oven controls won’t work, the range top will function.
The oven hasn’t been in the self clean mode for about two weeks. We used the oven since and it worked fine. The oven being to hot is not an issue as it is at ambient temp. When the oven temp sensor is disconnected the oven door locks and won’t unlock randomly as when it is connected. Did an ohm check on the oven temp. sensor and it shows continuity.
When i put clothes in the dryer and hit the normal start all that happens is the panel shows sensing, but it doesn’t start. Ordered new sensor harness and sensor, changed the harness but the sensor is on back order, however the one on it is almost new so i am not sure what’s wrong. HELP
