GE Oven Won't WOrk
Hello,
My oven is not working. Will not light or heat up. The broiler and range are operating fine. This is all powered by propane gas.
This happened several months ago and I reset the circuit breaker and it fixed the problem. That didn’t work this time however.
Any help would be appreciated. Thank you.
-Jennifer
Jennifer,
The model number you posted does not come up. Verify and repost it.
OOops! That is…JGBP28WEA4WW
Most likely the problem is a bad Bake igniter (#28 on the [B]diagram[/B]).
Remove the bottom drawer, disconnect the igniter wires and check it for continuity.
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5130251
