The ice makeer green light is on and does not blink. No ice and there is no water in the tray. The water in the door works. Are there 2 water intake valves?
David,
Make sure the water feeding tube into the ice maker is not frozen. If it is, use a hair dryer to clean it.
Swap the wires on the water inlet valve solenoids (on the back of the refrigerator), press the water dispenser release for a few seconds and check if there is water in the ice maker.
If there is no water and the water line for the ice maker is clean, replace the water inlet valve.
- The water inlet valve AP3192626
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5130616
Gene,
I kind of did that. I put a 120v directly on the ice maker part of the solenoid and water flowed in to the the ice maker. I guess there is not signal going to the solenoid from the ice maker. Do I just replace the ice maker and figure that is the problem?
-David
David,
If the water valve is good, you may want to check the wires from the ice maker plug to the water valve solenoid.
If there is nothing wrong, replace the ice maker.
- The ice maker AP4345120
