GE Profile leaking water for cold water supply into drum when not in use
I have a GE profile washing machine that is leaking water drops into the tub when it is not running. It is coming from the cold water supply, I shut the external supply valve and it stopped. I assume the washer in-let supply valve is bad. After checking the diagram it looks like item # 180/n AP3205006 is the part, but the drawling and information is vague.
Can someone with more experience verify this is a correct assumption and if this is the correct part # to purchase.
Thanks,
Joe, Thanks very much for your fast help. n An order will be placed shortly.
-Kevin
http://www.venicebeachvillas.com
:slight_smile: Everything Fixed. Thanks all.
— Begin quote from venicebeachvillas;618204
Great,
Thanks for the update. You did a great job.
:smiley: :smiley: :smiley:
